jleonardwv
Tractor whines in all gears.
I'm splitting my tractor to find the problem, which I assume is a bad ball bearing. Never split a tractor.
I've taken off most of the external stuff but can't get the hydraulic lines loose. They are so stubborn! I can get the nuts to turn, but they also turn the fitting. Most of them I can reach with two large wrenches, so I assume I'll be able to eventually get them loose. But the fitting that runs to the SCV under the seat from the rear gear pump doesn't have enough room for both wrenches.
Any idea how to get this loose? I'm considering order a "thin" wrench which might fit in the narrow space.
