Dons Small Engine Repair
New User
I have a small PTO operated Hydraulic system on a Tractor that was taken from a Massey Ferguson, its got a side mounted tank that Ive recently removed to replace the filler/Breather cap assembly, I had to make a new gasket that has leaked, I used a bulk gasket material and sprayed it with HI Tack Permatex, not sure if it is broken but it leaks, suggestions for better material to make this from, I have no part numbers on the tank for taking to a shop, I made the gasket easily, drilled holes, and sprayed, but it leaks no matter how tight I get the bolts, Needs suggestions for better gasket,
