I recently took ownership of my dad's Case IH 244 tractor. According to him, the radiator needs to be replaced, the water pump needs to be replaced and there are a couple of hydraulic leaks. The tractor has a Mitsibishi K3B 3 cylinder engine.
Before I replace the radiator I plan to flush the system several times and replace the water pump to see if this is possibly the issue.
The issue I am running into is finding a replacement radiator as Case does not offer a replacement option. While I hope to not need the radiator, I would like to know a source to find one.
Thank you for any help!
