billsanfilippo
New User
I am in the process of rebuilding power steering gear box Ford 800 -Started out as a leak at the top of the steering column. Found the seal surface of the steering shaft was well pitted so decided to replace the shaft. All was going well until I got to removing the adapter. It would not slide off the steering shaft. I finally got the shaft out of the casing with the recirculating ball unit still attached removed all the balls and slid everything off the shaft that way
Now my problem is removing the needle bearing and seal from the adapter. To give you some idea of the situation, the needles in the bearing are rusted and will not move.I assume the bearing race is rusted to the adapter. Tried tapping to no avail (surprize!!) Can it be pressed all the way through?? That would mean pressing the bearing and seal at the same time. I can"t see any ridge beteen them but I can't be sure. Any advice is appreciated Thanks, Bill
