478ntractor
New User
1st ever using and or owning a tractor.
Always wanted an old Ford 8n and found one close for cheap.
Engine starts right up with minimal choke.
Idle is strong and steady, no missing in timing.
gauges work Amp and oil.
Clutch is noisy when idling and quiets once engaged. (bearing)
Stinking rear hub is seized on one side. heat and wedges didn't work. Puller and heat next option.
Then have to figure out what is holding onto the differential inspection cover. Right side is hanging up somewhere internally.
steering is sloppy as a pig pen.
lots of parts missing and more I have yet to figure out.
