Company Logo Shop Now
Restoration & Repair Tips Board
Re: Farmall Wheel Weights
Randy-Ia
09-15-2020 20:41:26
Don't forget that rocket science hadn't been invented when these wheels weights were. The first weight, whether a half or a whole, was held on with two bolts, it didn't matter what length they were or whether they were hex or square headed. The second set was also held on by two bolts the same way. They locked into the notches of the first weight. 4" should be adequate for each slab. Lay the slabs on the ground, measure how far apart they sit and do the math. I have three sets of half weights on my M. I used stainless bolts because that's what I had. Obviously stainless wasn't an option when these weights were offered from the dealer. Don't overthink it. Super or not, these rims are all the same. The suggestion to use all-thread is a good one. Use it- cut it off to length. Use some blue lock-tight or Stover lock nuts (deformed), even some nylock nuts will serve you well.
Copyright © 1997-2020 Yesterday's Tractor Co.
