9N fails to start even after upgrade to electronic ignition
kpaddock
New User
Decided to upgrade 1939 9N to electronic ignition after many failed attempts to get tractor started after replacing points, condenser, cap, rotor, coil and after upgrade with PerTronix kit, still non starting,anything that I have not considered, even have a new battery? Resistor needing replaced?
(quoted from post at 11:38:39 06/27/20) Decided to upgrade 1939 9N to electronic ignition after many failed attempts to get tractor started after replacing points, condenser, cap, rotor, coil and after upgrade with PerTronix kit, still non starting,anything that I have not considered, even have a new battery? Resistor needing replaced?
ppears to be a mis-use of the word 'upgrade'. :roll:
You are throwing parts at it without knowing why it won't start. Electronic ignition doesn't solve your problem. Go over to the 9N/2N/8N forum and get help there.
