19-71 dearborn loader valve parts
Hey all, trying to source the seals for my dearborn loader valve body. I have a part # on one of them of 6208-CR but that comes up with a bearing number. I need the two seals that are 1.125 inches OD, .625" ID and .50" wide
(quoted from post at 21:37:06 06/27/20) Try SKF 6203.
It's only .250 wide, but you can put 2 in, one pointing out, one in. That will keep grit out, oil in.
Look on page 63 for other options.
SKF Catalog
I was thinking the same thing but i'm thinking that because these are typically rotary shaft seals they wont hold up to the movement of a shaft back and forth through it
NOT at all hard to find on the .net.
Go to https://www.skfextranet.com/crsealsfinder
Enter "6208".
Thanks for the info. I found that #6229 earlier, but in the description its .375" not the .50" like in your info. (IDK) I'm probably just going to try it out
