Copper squish (crush) washer for f11 loader
Looking for the copper squish (crush) washers for my f11 B farmhand loader lilt cylinders. The kit I bought doesn?t come with them. Local guys says they don?t know where to get them. Anyone know where or and equal fix?
How large are they?? If in the 1/4-3/4 inch size most auto parts stores keep those in stock and you can buy pack of 5-10 or a assortment pack
i just got some copper crush washers on amazon. search for banjo bolt copper washers. i got them for the oil filter housings on farmall h and m tractors. they ended up being a metric size.
I believe the washers in question are somewhere in the 2.5" to 3.5" range, the same I.D. as the cylinder "gland" seal O-rings.
Here's a comment I found on another message board... "Turns out they do not use copper anymore. Now they have neoprene o rings with a special metal seal ring to keep them from rolling out. Also turns out you can't order 4 of each, only sets of ten."
Is it possible anything like that came in your kit?
How about the old copper rings, are they destroyed or just :hardened" and bent up a bit?
If at all salvageable, you can anneal them to soften them back up, then tweak 'em back into shape.
Heat them cherry red, then toss 'em in a container of cool water.
1 was good. The other had been over tightened and all mushroomed so I just flipped it over. It kind of worked but if I could find some I?d replace it
I?m positive if you get the Agco kits it comes with instructions on the update . I may be wrong because I haven?t been into those cylinders for a few years
