I needed to cut a pto shaft in order to fit an old implement I repaired to a tractor. Measured distance and figured how much I needed to cut off of round outer tube of pto shaft and then was going to cut the same amount off of solid square shaft attached to tractor end yoke. When I cut the round shaft, which was easier than I figured it would be-discovered that it was beyond the solid part of the outer tubing. Noticed that this solid end was welded to hollow round shaft. Now I'm not sure what to do-have an idea. How does this work? Do I need to bring solid piece to machine shop to be cut back then inserted and rewelded to round outer pto shaft??? Something I can do myself? Did search and could not find answers. Thanks in advance for guidance and help-
rookie
rookie
