Getting parts cleaned?
dacaseguy
I do some rebuilds and I always have lotta small parts nuts bolts washers etc. to clean up and get the rust off. What do you guys do to clean all those besides just using a wire brush. I was thinking of getting a Tumbler ?
I'm thinking you would be better with rust removal chemicals, electrolysis, bead blasting, wire brushing, even a needle scaler for the bad stuff. Each has it's own application.
A tumbler will only get to the surfaces the stones can reach. They can't get into tight corners or down into threads.
If you reload ammunition you might use the brass tumbler to clean the bolts. Use something coarse like walnut shells' or sand.
