Ohio88
- Location
- Fairborn, Ohio
Been working on this super 77. Trying to work on the clutch. The clutch shaft will not come out of the bearing. The bell housing will not go over the coupler splines. I
thought the shaft was stuck in the clutch disk so took bell housing loose and was able to get the pressure plate loose and it changed nothing. By using a slide hammer
the shaft will move about 1/16 of an inch. The motor is out and all that happens is the motor moves. It Is definitely the shaft stuck in the bearing. Any ideas on how to
get this out.
get this out.
