pathfinder
New User
Aquired a early model 1070.
The 3 point hitch won't raise. There is a dipstick located left rear behind the rocker shaft and above the PTO.
However, unsure that is the proper filler location, since finding references to a sight guage on the left side of transmission.
Have found no sight guage, but indication that one may have existed and is now replaced by plugs.
H/T fluid may not be the problem, as the DOM sense lever is pulled to the rear and seems to be immovable.
I followed the Sense cable to beneath the seat where it was attached to a short pivot arm on the upper end of a vertical shaft. The shaft's arm has a return spring.
The shaft will not turn!
Tnx for any advise. lef
