Good day.
I had posted a couple months back. Centerplate helped me out quite a bit heres a quick synopsis: replaced centerplate valve seat for poppit and had a new poppit machined for me. Put it all together and started getting 400 psi which was way better than 100psi.
I put a tee in the main bucket lift line and ran it to an on dash psi gauge so I could troubleshoot. When I raise the bucket and top out the tams it will go to 400 and start settling backwards toward 300. There are no fittings leaking that I can see.
One night without me pulling the lever I had it running and it slowly climbed to 850psi then some fittings were leaking so I shut it off and tightened the fittings but haven't got it past 400 psi since.
This tells me the pump is making enough pressure and the poppit atleast seats sometimes. I just wanna give up at this point, any help would be great, thanks.
