Dearborn Loader 19-71. Restoration/System Flush Question
Kurt J
I was able to pick-up a Dearborn Loader for my Ford 860. It is a Dearborn 19-71. My question is....How do I clean the oil reservoir, which is the frame tubing? It has been open to the environment (a large rubber hose was missing), so I'm sure there is rust, bugs, cobwebs, dirt and maybe a mouse home in there. I'd like to try to clean/flush it out prior pumping all that crud through the pump and valves.
That might be tad bit light for that tractor. I have the same model loader on my 8N. To clean it out one would need to figure out a way to pump something like diesel fuel around in it and then drain that out. Rigging up a drill pump might be the cheapest way to go
Thanks Old! I'll flush it with some diesel fuel. Probably hook up my shop-vac and get the loose stuff first. Thanks
Kurt
