Fairlane514
In my quest to fix my idle problem (stumble), it clears up and runs great with about half choke. This means to me lean or unmetered air getting in. I took my carburetor off again and this time i concentrated on the throttle shaft. When I rebuilt it the first time I did not install the new throttle shaft. I removed the old throttle shaft this time and measured it .247 thousandths just like the new one.
Taking a closer look at the bushing I could see it was well worn and the shaft wobbled significantly in the bore.
I have rebuilt many Quadrajet, Edlebrock and Holley carburetors and a loose throttle shaft bushing can cause a vacuum or unmetered air leak. I think this may be my problem and I found a new bushing online.
Alsp, my float level is correct and my mixture screws and.....Main meter 1 1/2 turns out, idle mixture is 3/4 out. Turning the idle mixture does little, all the way in and still runs better with some choke. Turning it out doesn't do much either.
I will report the findings, if any.
I just rebuilt the engine, and fired it today, it runs fine above idle, so again it leads me to a vacuum leak.
