mbrady.glide
Has anyone had success using Evaporust in an engine with pistons stuck? I have a Detroit Diesel that I can't get to turn over and was considering pulling the head and using some to get the pistons loose, if that is indeed the problem. Think that it would penetrate between the rings and cylinder wall? Obviously would be changing oil afterwards, so wouldn't worry about contamination that way.
Several YouTube channels I watch are using it profusely in tool restoration, so figured it would be worth a shot in this application.
