I have a MF 35 diesel with a 12 volt positive ground system. The generator has 2 terminals which have no markings. One is a small tab and the other is a much larger tab both on the back end. It has a VR that is buried in behind the console. I had the gen. rebuilt. When running it charges fine. When not running it kills the battery. Do I need to polarize the gen and what is the proper procedure?
The only reason for rebuilding the gen is that the bearing seized otherwise everything was working fine.
