Ford 4000 hand control and position control arm
Tony Puma
New User
Hi, years back I messed up the friction plate and lever on my lift trying to remove them. I'm now on the other side and have found that the turnbuckle had fallen out. Trying to remove the entire assembly I hammered off the hand lever control and am now I'm looking at removing the position control arm. Do these arms normally come off EZ?? I feel like I shouldn't have to hammer these off?? Did I mess up?? I attached a couple pictures.
Ok , I have it all apart now. Once I got the friction plate off it all slid out. The only part I can't find is the draw bar control assembly spring or its called the position control spring. 3/4 OD .5 ID X
1.187 L the wire is .135 DIA. Its the shorter of the two spring not the longer draft control spring, the longer spring I could find. Both springs seem to have the same wire DIA, the same OD & ID but the length
are different. I need the spring you can see in both pictures. Thank you, Tony
