RUSTYWAYNO
New User
Hi everybody thank you all for letting me join your forum i have read many pages and topics that have helped me with my tractor. Ive come to join and seek help and help others whenever i can. My tractor i believe to be a 1957 Case 320B wheel loader backhoe with gas engine and the shuttle shift forward reverse with four speed transmission high and low range. I purchased the machine like 10 years ago an got it up and running pretty good and used it to scrap vehicles to earn the money back i spent to buy it with which at 19 was a big purchase at $2500. The ol girl has come a long ways, recently lost oil pressure and took lower end of engine apart to find oil pump shaft key had rolled out. Luckily with the help of a friend with a bridgeport milling machine he was able to cut a new key slot into pump shaft and i was able to reassemble pump and get it back up and running and have great oil pressure again. since the tractor has been sitting a year or so up until i got the oil pump fixed i have ran it and dug in the dirt and operates great just now i have no drive clutch what so ever. The tractor ran and drove and functioned properly except for no low range, but since has set i no longer can drive it. i press the clutch pedal and their is hardly any pressure cant believe the clutch pressure plate or springs would fail not under use. i can start the tractor and shift into any gear with pedal up and transmission doesn't make any noise what so ever. It never slipped when i was using it regulary to push and lift trucks and cars around. Any help is appreciated greatly thanks
