Filling Hydraulics
RTH
New User
This is my first tractor, Ford 640. Manuals I have show the fill plug on the left side, but mine doesn't. Looking for info. Thx
I believe the fill is to the left of the spring on the top link. It just looks like a fill plug,you will know as soon as you take it out.
Hyd fill plug is sort of under the seat on the left side and sits at a 45 degree angle. Just looked at my 841S just to be 100% sure where it is
I was told the lift cover is off possibly a 2000. No fill plug on it. Mine has 3 separate chambers, hydraulic, transmission, rear.
All 600/601/800/801 have 3 places for fluid transmission hyds and rear end. Even if the lift is off a 200 the fill should be below the seat on the left but it you have an aftermarket seat the fill plug could well be hidden by the seat. My 841S has a rest to ride seat and if it was moved forward on the ,mounts the fill plug would be hidden by the seat
Nothing there. Not the rht lift cover. Had to take pto lever cover plate off to fill
