Gooniebird63
New User
My 1944 2N started blowing oil out of the top seal of the oil filter canister, It would stop doing it after the engine was running for a few minutes. I had to take the oil pan off the other day because my governor gear came off the shaft of the governor and chewed up the timing gear and I took the oil pan off so I could clean all the aluminum gear shavings out of the oil pan.
I got it all back together with a new governor and it started right up but still blows oil, I shut it down right away so I don't know if it will stop after a few minutes or not, I didn't want to cause any damage to occur.
I put 6 quarts of 5W-30 in it after I had it all put back together along with a new oil filter and canister seal.
It has been cold here, between 30 and 20 degrees F.
Is the oil too thick or is something wrong with the oil pickup in the pan?
PLEASE tell me I don't have to pull the pan off again!
