Gooniebird63
New User
Hi, My 9N started high idling and I noticed oil coming out of the governor where the oil feed tube would normally be, the fitting fell out while plowing my driveway, I don't see the oil feed tube that is supposed to be attached at the elbow fitting, Is it possible that hole just had a threaded plug in it? If so, how would the governor get oil and also if that is the case, do I fill the governor with oil and plug the hole or what?
I attached an image of the threaded elbow fitting that I found on this forum.
Thanks in advance!
[/img]
Thanks in advance!
[/img]
