TO 20 Hyd Pump Parts
kentrann
New User
Greetings,
I am looking for a pump cam for a TO 20 Part number 181070M1.
I am hoping someone here may be able to steer me in the right direction
Thanks.
K
Hi Kent?
I believe I can find you a new one. I would have to find out what the cost would be. If you like I can look? My E-mail is open....bottom right...classic view.
Wayne
Are you sure you have the correct part number? The TO-20 and the Ford 9N have the same hydraulic pumps so the parts are interchangeable.
Harry Ferguson designed the Hyd pump used in the TO-20 and To-30, possibly others but I don't feel like pulling out the parts
manual. Henry Ford used the same pump in the 9N and the 2N. You could put an 8N pump in your To-20, but that will also require
changing the top cover, however you would get built in position control.
