I'm installing an Pertronix Ignitor electronic ignition with the 40,00 volt coil. It's instructions indicates a minimum primary resistance of 3.0 ohms is required.
My question is: Do I go directly to the 12V battery though the ignition switch or do I need to go though either the ceramic resistor or the spring look resistor, or both, before going to the coil with the positive wire.
