Company Logo Shop Now
TractorLinks.com
Restoration & Repair Tips Board
Re: Coolant Heater
Jim.ME
11-08-2018 19:27:52
What do you mean by newer models? Unless your engine is different than I think it is, it will not accept any of the in the block type heaters Bob's post showed. I think you will be fine with either the factory tank heater or one of the aftermarket tank heaters. Kats and Phillips both make good tank heaters (and cost less). 850 to 1000 watts will be plenty, (1500 watts maximum) no need to go larger.
When you say under the seat do you mean; under the seat on the side of the transmission, or actually under the seat on the cover the seat mounts on? If we are describing the same place, side of the transmission, that would be a tractor S/N 187300 or before.
