Ford 7000
New User
I have a Ford 7000 with single speed pto and load monitor. I have pulled the IPTO clutch and it is a 3 disc clutch pack.
I c that they make 4 and 5 disc clutch packs. Can I use a 4 disc clutch pack? And does anybody know why they made clutch packs with additional friction plates (discs)? Thanks.
Ford 7000, Does anybody know why they made clutch packs with additional friction plates (discs?
The more discs the greater the friction area,= more holding power to keep from slipping.As far as just adding more disks I'm not sure if it can be done with your existing housing,without replacing it.
I see. I was going to buy the whole clutch pack anyway (comes with the housing). I just wanted to put the heavy duty clutch pack in. If they weren't $250 each I would order one of each and compare the housings to c if they fit.
Thanks for the reply
