bry
New User
I have a 1965 Case 541. At least I think that is the case.
I am loosing Hydraulic fluid from the hydraulic reservoir to the rear end. So much that the pumpkin breather valve is leaking hydraulic fluid. Why is this happening? Is there a pump gone bad inside the transmission or a leak somewhere else?
It could be the system is over filled,or over full from water/condensation.Crack the drain plug slowly and look for water dripping out.If so drain all the water out,then tighten up the plug.
This has been discussed over and over again down on the CASE forum.
It is most likely that the packings on the 3pt cylinder are leaking hyd fluid into the rear end.
Scroll down to Case forum. and you will get all the answers you need.
Loren
