Company Logo Shop Now
TractorLinks.com
Restoration & Repair Tips Board
1080 Massy lift arms
Big DP
02-13-2018 08:39:37
My 1080 Massy lift arms on start up come all the way up. I have manipulated both control and draft arms in all positions with no luck. I have the right side plate off I can move the linkage arm back and forth there is no tension on the linkage in any position with the tractor running. I do have go flow through the standpipe. What gives?
Dieseltech
02-13-2018 09:39:50
 Re: 1080 Massy lift arms in reply to Big DP, 02-13-2018 08:39:37
Sounds like the inlet spool control valve is stuck. There's an oscillator that constantly rotates the valve slightly to help prevent sticking. If the oscillator drive fails, it WILL stick. If that's the problem the lift cover has to come off, and a rear trans-diff case joint split is needed before the three point pump can be removed out the diff case front.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
