Anonymous-0
I am going to be converting my 3020 gas (positive ground) to a negative ground alternator system. I was planning on using kit AKT0017 from dbelectrical.com. It comes with starter, alternator, mounting bracket, solenoid, amp gauge, and wire/cables. I was wondering if I should also change the coil, but I noticed it says 6 volt on it. Isn"t this a 12 volt system? If I change to 12 volt neg. ground, do I still use a 6 volt coil? Also was thinking of upgrading to the electronic ignition conversion kit from this website. Which one would I need the 12v neg ground or the 6v neg ground? (after my pos to neg conversion)
