From my travels around the internet I'm getting the idea that MS TSX carbs were used on a number of makes and models. On my Case VAC's I've got a TSX 114 and a 587. As far as I can tell, the only difference between the two seems to be the throttle shaft linkage. Is it generally true that the differences in these carbs mainly run to external linkage?
I'm in need of an upper casting for a TSX 114, if all of the small bowl models are the same for that part, it would give me a lot more options trying to pick up basic parts on eBay or elsewhere.
Thanks!
Thanks!
