Hello everyone, I have a 1941 Farmall H that I am in the process of restoring, and have discovered that the front crankshaft oil seal is leaking. The engine is all cleaned and painted and when I went to add oil to the engine, it started to leak immediately behind the crankshaft pulley., and naturally stopped leaking after I stopped adding oil. The tractor is still disassembled partially, meaning the radiator is still off of it and various other parts so I can't tell how bad it will leak with it running.
Is the front crankshaft oil seal removed by removing the crankshaft pulley and if so can it be done without removing the front bolster to gain clearance to remove the pulley? Or does the front crankcase cover have to be removed and the seal taken out from the inside of the cover?
Thanks for any input.
