Freeze Plug in bad spot to replace HELP.
Shealray
This is my Ford 850 I am working. The freeze plug is located at the bottom and there is not a straight spot to push in the new plug at the bottom. An engine casting is in front of it. I removed every thing there was to be moved the battery box and so forth. I tried putting in a new one and it looked like it worked. There is a small leak at the bottom of the plug. My husband and I spent 2 hours tapping around trying to seat the plug. The bottom of this plug sets in a notch. I am guessing when the factory installed the plug the transmission was not attached and they had a straight short to install. So who cares about the poor people having to replace them later?
Here is my beginner’s question. Can a put a silicone in the bottom of the plug to seal it? If not then with out buying plug tools tell me how to put this plug from “H E double tooth picks” in.
Hope the pictures I gave can help you see the how hard this is to seat.
Be Safe Be Happy
Shealray
At one time they made those from neophrene sold at your local auto parts store. You just used a wrench to tighten them. Call your local auto parts store to see if they have them. They were made for hard get to places. Hal
SUPER. I used what you are talking about to plug a hole in a metal water tank. This is a case for “You can’t see the forest for the trees” Have to look a another’s point of view.
Thanks for the help.
Also should add. I saw a guy pack the plug with JB weld. Stopped the leak and was still working six years later when he sold the truck.
You don't need a straight shot to drive a new plug in... You will have to make a driver to do it but its EZ to make... If you search the Ford board I have made a post on how to go about it... I have done harder that were almost impossible to get at...
the compression plug is basically a neoprene plug that is sandwiched inbetween two metal washers, just tighten with a wrench. of course they are not as pretty, but they work well.
i'd put a new plug in, and coat the id of the hole, and od of the plug liberally with #2 non hardening permatex.. that way if ther is a minor imperfection in the casting it should seal up.
soundguy
