ELECTRIC FENCE MODIFICATION TO USE TRANSFORMER INSTEAD OF CAPACITOR?
Hi folks. I have a major deer problem that to date no fence charger will deter.
I have a ZAREBA A5 model :115V04J-4 electric fence charger (5 Miles). I would like to convert this unit to use a car ignition coil instead.
The output from the 741 op-amp switches the gate of a small MOSFET (or it could be a JFET as I cannot read the component) to charge a large (unknown value) capacitor to give HV to the fence.
I was wondering if I took the drain of the (TO92 and unmarked) MOSFET directly to the emitter (via 100k resistor?) of a 2N2222 or BFY51 to drive a 2N3055 or similar, then used this to dive a car ignition coil. I would use a snubber to deaden the voltage peaks, of course.
Any help would be most appreciated.
I do also have a couple of transformers from ordinary none electric fence chargers and would like to use these too, if possible. Could the output from the capacitor pump the primary of one of these transformers? Easiest possible way... Thanks.
