Sometimes my starter keeps running after the engine has started. I have confirmed that electrical connections are tight, good battery ground. I ordered a new ignition switch, which should be here in a few days, but if it isn't the ignition switch, then my next guess would be that the thing on the starter that moves over to mesh with the teeth on the flywheel isn't retracting when it is supposed to.
Are these the two most likely things? And, if it is the starter retractor thing, is there a way to test it?
(Delco 1107755 starter in a 1959 Case 510B)
I don't know if this makes any difference, but this was a positive ground that was converted sometime in the past to a negative ground.
