The tractor will run fine and start fine until it gets hot. When it gets hot it would drain the fuel filter and would die because it was not getting enough gas. We checked the fuel pump and its working and the fuel lines are open. Any suggestions on how I can keep gas comeing to the carb?
check the fuel tank cap for unrestricted vent. leave the cap loose or off altogether and see if that helps. what about crud in bottom inside of tank being drawn to fuel line inlet as fuel is being sucked into line? good luck, d.coleman
