MF175 Clutch
dirtfarm
New User
Clutch was working fine, now I can not engage gears it grinds, it also grinds turning on PTO, does not slip at all. MF 175 only had the tractor a few months, no muti-power, 3high 3low. Everything works fine after engaged
Check for clutch disc siezed on splined shaft, disc stuck to flywheel, and condition of release fingers and their pivot points.
found broken clutch release pivot pin. is there a good manual that shows where it goes, or an online diagram?
OEM Massey Ferguson manuals are best. You'll need the service manual. Parts manual shows exploded view, as well as listing descriptions of parts.
