Heston 5530
LynV
New User
HI
Have a heston 5530 round baler
the barring went on the square tube roller
how hard is this to get at?
if i take off the large springs will it flip over out of the baler so i can get to it?
thanks for any advice!
I have a 5580 two years ago I had a bearing go out and it tried to catch on fire you don't want that to happen in the middle of a hay field. I replaced all the bearings on every roller. I figured if one went I may have some more going bad and I found three more that were questionable.
The hardest part was removing all the belts and putting them back on. Mine has eight belts.
(quoted from post at 18:42:33 03/21/09) I have a 5580 two years ago I had a bearing go out and it tried to catch on fire you don't want that to happen in the middle of a hay field. I replaced all the bearings on every roller. I figured if one went I may have some more going bad and I found three more that were questionable.
so if i remove the large springs it will come out?
i have had this baler for a long time now, should propbly replace most of the bearings like you said
thank you so much Roy !
