Hi all. I'm new to this site - I found it because I am going through a rebuild on our Ford Super Dexta tractor. The tractor has the 152 Perkins in it. We are rebuilding because it dropped the #3 sleeve into the oil pan.
Right now we have the tractor apart and the engine on an engine stand. I have been looking around this site for a while now, and have found a lot of good information on these sleeves. Last night we took the pistons out, and the rod bearings didn't look so good, so I'm not expecting much from the mains. So it's a complete rebuild this time. Since it's a complete rebuild, I would also like to replace the other two liners. But I still have a couple of questions:
-When I go to install the new liners, how much force will actually be required? I have read a couple of accounts, and they varied from "you can spin them by hand when they are in" to "they should slide in halfway, then you need to pull them". Which is right?
-I plan on purchasing the parts from this site. From those who have experience, do the new liners come bored to the correct size, or is a trip the machine shop in order? If bored, I assume they need a finish hone?
-Is it acceptable to freeze the liners before installing them? I have heard two thoughts on this. Also, should I warm the block as well?
-Do I need to use any locktite, or anything else to secure the sleeve in the cylinder?
-What are my options for the cylinder that dropped the sleeve if the new sleeve is loose?
-I plan to clean the bore, but do I need to hone it before installing the new sleeve?
Sorry for so many questions, but these are the ones that I either haven't answered yet, or just want to double check. Thank you in advance for any information.
Ryan
Ryan
