w-9 engine
w-9 nut head
09-26-2023 18:13:22
Wondering if anybody has done anything with these engines to get more hp out of them. Has anyone stroked a crank.
cumminstinkerer
10-26-2023 11:13:50
 Re: w-9 engine in reply to w-9 nut head, 09-26-2023 18:13:22
I do not but he is on the board of the NATPA I believe. He doesn't do the machining himself but may have someone that will, also maybe reach to Loren at Z Machine in Ocheyedan Iowa, he used to do oddball stuff like that and cranks are his deal!
w-9 nut head
10-25-2023 18:08:12
Do you have a contact for this Josh. Nobody doesn't really want to mess with cranks for some reason saying the oil hole would be tough to move over.
cumminstinkerer
10-25-2023 08:31:41
Reach out to Josh Hannah from Bolkow MO, he is pretty good with the big IH stuff, the one guy I knew that played a lot with the old 4 cylinders died about 20 years ago, he had a 22-36 that he stroked 1 3/4" I think, he bored it 3/4" agian if memory serves, was using pratt whitney pistons, rods were bottoms and Pratt tops, he just doubled the cubes on her, them old slow motors are pretty forgiving. If you have someone do the crank make sure they radius journals right, my buddy broke one because they didn't.
w-9 nut head
10-15-2023 16:16:25
Ok Question What is the difference between the W-9 head that is a gasoline engine and a 650Lp. I know the compression ratio would be higher but are the ports bigger in size for air flow.
w-9 nut head
10-02-2023 08:45:02
Custom made or IH made them.
Frank Caldwell
09-27-2023 17:30:47
I had the head ground down .030 and use a higher octane gas.
w-9 nut head
09-27-2023 14:44:47
When they stroke the crank are they using stock bearings or something else for the rods. I have bearings but my problem is nobody wants to stroke the crank for me says its an odd ball engine at 335 cubes. Is there someone you know that will do it.
VicS
09-28-2023 03:25:43
 Re: w-9 engine in reply to w-9 nut head, 09-27-2023 14:44:47
Try H.A.P.I. at Terra Haute In. (Spelling?)
VicS
09-27-2023 12:09:45
There is some guys talking about them back in 2012. They said 9 1/8 stroke and 5 1/4 bore. Think that is around 760 cu. Bearings are almost impossible to find. Thete is people that will make them. Same with gaskets. But don't really need a head gasket. Fire rings are better. Best to put a Red Diamond motor in a 460 ihc.
Roger in Iowa
09-27-2023 12:05:32
Original bore was 4.40 inch. Later sleeves are 4.50 inch. Cubes went from 331 to 350, I believe.
rustred
10-01-2023 08:33:46
 Re: w-9 engine in reply to Roger in Iowa, 09-27-2023 12:05:32
there was also 4 5/8 bore sleeves for them engines.
