kub6040
I am putting a 301 in a 460 to play and want to know if there is a better manifold carburetor set for it, not looking to turn more than 2400 rpm , running 9 to 1
Looks like a lp. manifold on e bay for $90. That is about as good as it gets. Unless you make one from tubing. Both will need wrapped with exhaust wrap. To help with icing. Do you have the carb from a 806 0r 503 715 combine. Think they change the venturi also. Or look up motec Carbs. They worked magic on mine.
