Farmall 300 head gasket
Hello Deerepower welcome to YT! Odd user name for
someone looking for Farmall parts. Have a NAPA
nearby? See link, hope it takes you the right place, make sure they double check that is
right Or Oreiley can if you have one and the counter
man is not to green as in lacking experience. Likely
most any auto parts store can get one if you sweet talk
them right. FYI when replacing a head gasket on a Farmall it is recommended to warm it up good and then re-torque the head bolts while the engine is still warm to the touch. You will have to pull the rocker shaft to do it, reinstall then reset the valve clearances.
Look here
Used red MN it s my dads tractor I have a John Deere 720 I pull. Thanks for the info I ll run by O Reillys and see if they can order one Napa says they can t.
