Talala Okla Pull
Topsarg
The GCTC will pull Antique Tractors this Sat the 8th of Oct at Talala Okla starting at 1030AM. Classes start at 2600lbs and go thru 7000lbs. The Equalizer Sled will be on hand. Come Watch or Pull. Info call Jim @ 918-483-7775
I went and looked up Talala and saw that it was on Hwy 169 between Nowata and Collinsville...I then realized that I had been thru it several times as recently as Sept 2021...Is that the first time GCTC has ever been there?
If things go as planned I hope to come and watch the GCTC pull at Catoosa,OK on Oct 15th...I can also see the Rt 66 Flywheelers show at the same time.
