LP intake vs gas
Dennis P
(quoted from post at 17:02:42 02/02/22) Running a 220 w/LP head out of a ZA in my R. I noticed that the lp manifold has a smaller port size than the gas manifold. Seems like the lp would need to be widened at the flange port to match the bigger gas carb/spacer? I like using the Zt setup because I like the exhaust it has. Any thoughts on running the lp setup? Does it help to use the lp intake? Should it be modified or should I just stick with using the stock ZT manifold? Thanks in advance!
Well you sure don't want to have your incoming air hitting a ledge. I have had to wrap a 3/8 copper water line around just above the.carb. then header wrap around that.
