Super w6 vs Super M
depends on what you want to know. if your asking about pulling they are quite competitive. it seams that the M does a bit better due to the taller rear tires. i have watched the both pull. its all about operator also. you wont say M hands down.
Well, I'm pretty sure they both have the same engine. Possibly a different engine block, But I think only externally if thats the case.
So, all the difference is in the tractor configuration with the Super M being row crop, and the Super W6 being a wheatland.
There is quit a little difference in the configuration, so I'm not going to get into that, not knowing for sure what in particular your wanting to know in regards to that. Pictures of both can possibly be found right here on yesterdays tractors.
same engine same rpm , only difference is in the gearing and tires. thats where the slight advantage comes from.
Everyone can run the largest tires the class allows. No matter brand or conformation. A w6 can be a little lighter than a M. Because of shorter axle housings. Front end can be made as light as you have imagination. All gears are faster. On a w6,with a monster motor that would be a advantage.
Without putting a lot of time into the standard, Id have to disagree. I say super M by a mile A W6 has the same motor, but its a shorter tractor with a long baggy drawbar, real nose heavy and smaller tires. Even if you go ahead and put 38s on one of these, theyre geared higher than a row crop so it isnt as great as it sounds
