4020 pulling clutch
PreCuts
Have 250 horse syncro 4020 John Deere that runs in 3000 rpm farmstock . I put 4320 springs in clutch but it not holding . What can i do to have a clutch that holds the will not break the bank.
This post was edited by PreCuts on 09/26/2021 at 01:51 pm.
When we set up our 6030 we got our clutch from Darrin Rursch from Taylor Ridge, Ill.--He is a crower dealer--Nicest guy you ever met...He knows his clutches. Sorry but I don't have a phone no.---Tee
Ok so here what I am trying . 4320 clutch with heavier springs and added washer behind springs . Then Kevlar pads against flywheel and ceramic on clutch side for disc . I know it not a pulling clutch but Darrins clutch eliminates pto and he also said his is overkill of what I need due to this still being a farming tractor . This will cost me 1300 instead of 4500 . Atlas had one for 3000 that holds 800Hp but would also lose pto and I am not ready for that . I am more a local farmer that loves smoke rather than a dedicated puller . :D
When I was having clutch trouble, I went
to my friend Mike Sullivan. He looked at
everything and said it's not flat. Took it
to Jimmy Harrison at Albion il. He
polished everything. Both told me to heat
it up right before I ran. That worked! My
words of wisdom. If you want to win, it
has to be a pulling tractor.
well I resurfacing flywheel too . And yes I agree on the need pulling tractor but I am usually in top 3 in the local pulls . But not when I go out to where the big boys run . I pull for fun and yes winning is great but I have fun losing too :)
If Darrin is too salty for ya--Go to pulloff.com and ask your ?? on there. There are a lot of different pullers on there and guys always moving up in the pulling world and might have used clutches for sale or ideas what to do in your price range--Good Luck---Tee
