CNC-MACHINIST
MSD
I talked to one of the pullers from over at Marble Store this afternoon. He said the pull is on for Sunday this year. We are planning on going to the one in Ainsworth NE unless it looks like rain.
They will pretty much fit you in with whatever you bring. Mostly the same rules as Shellum's run. They did some upgrades to their sled this winter. Now has a speedometer so that should be interesting for some of the guys to deal with. Hooks have been only $10 in the past with cash payback but don't expect to get to rich. A full pull is if you put the front end in the ditch but stop short or they get upset if you pull into it.They have concessions on the grounds. Be sure to check out the A JD converted to a big grill smoker.
They have a scale and run 20 hitches. Good place to do test and tuning. Div. 2 will be 3.5 mph and Div. 3 I think is 5 or 6- he wasn't sure what they would run. They always had an open class too. They have a basic stock class also which is pretty much off the farm tractors, not the big heavy pullers but 5000, 7500 stuff.
