flembo
Back in May of 2020 you guys helped me with a problem with my Cub Cadet 1811 not going into reverse and suddenly jack rabbiting when in forward. Roger told me to swap the pressure relief valves which I did and the reverse problem seemed to improve a little but it has slowly gotten worse to where it would barely go up a grade in forward and worse in reverse. I bit the bullet and replaced both relief valves with new and it seems to be much better especially in forward, it went right up a hill that it couldn't before with power to spare. When I first started it after changing both valves it didn't want to backup at first just 3 or 4 feet and stop, but after a few minutes of circling around the yard it now goes into reverse and continues much faster than before. I would hate to have to replace it, I have a Snow blower, mower deck, roto tiller and forks for the 3 point. so it gets used a lot. Thanks again for your help 2 years ago.
