Company Logo Shop Now
Oliver 77 Engine and Modifications
TinkerPuller
05-01-2021 08:20:12
Hello all,
I am coming here in need of some advice. I have a 1949 Oliver 77 which I think was put together from parts long ago. I noticed when looking at another 77 my engine doesnt look like there, mainly the placement of the block drain petcock and the hour meter plate on the distributor housing.
Now I am no expert and used google to the best of my ability, and havent came up with a for sure answer.
The casting numbers on the left of the block are
Top: 185220B
Bottom: IM100B
Vertical above the starter: F32355
I been told its a Super 77 block, been told its a 770 block
Would like to know what it really is if someone can help.
From there I am wanting to know how big a piston I can run. I dont mind having to have the block bored for custom sleeves, and I dont mind having to Bush the rod for a automotive piston.
Just wanting to get as many cubes as I can without having a stroker crank made.
Any and all input would be appreciated.
VicS
05-03-2021 18:37:28
 Re: Oliver 77 Engine and Modifications in reply to TinkerPuller, 05-01-2021 08:20:12
Before you spend money on your 77 block. Find a 320 engine and spend your money on it. But the Big Oliver's start with a 426 from a gen-set. All these engines are Waukesha's which is what Oliver used. I have some friends that have some 400cu. Or so engines they might sell.
chucksoliver77
05-02-2021 14:24:21
If your lucky which I think you you have a super or newer block which should have 2 1/4" rod journal which can be offset ground to 2" giving you a 1/4" of stroke and use the rods from an early 77 engine. if you go with the 3 3/4" overbore kit an mill 1/8" off the top and your good to go. The head needs a lot of work (big valves and porting). you will have 265 cu.in.
TinkerPuller
05-01-2021 12:17:54
I highly doubt the block is right for a 49. I am just wondering what I have. I dont mind having the block bored bigger for bigger sleeves, I just wanna know what options are as making bushings isnt a problem to run a smaller pin. If I can machine the block for 88 sleeves and pistons and run the rods I already have, I would be fine with that.
Also are these wet sleeve or dry sleeves? I would guess dry.
Craig Thompson
05-01-2021 12:00:07
I am sure someone can help you with block numbers, But it sounds like you do not have a super motor. I believe the late model fleet lines started having Tach drive/hour meter plate below distributor.
The biggest oversize bore is a 3.75. If you go any bigger you would need to machine the block for bigger bore. I don't believe there is a off the shelf automotive piston that has correct wrist pin height for stock stroke so if you do not want to stroke it you would need to have a custom piston made or use a tractor piston from a bigger Oliver that may work, that would be from the 88 block family (88/1650) etc.
If rules allow you would be best with replacing the block with a bigger block, 88, 320 block or 310 block.
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos ... [Read Article]
Latest Ad: Armstrong 11.2x24 4 ply new never run,mounted on Allis B or C rim [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
