magnumpowers
Hi, I have an Oliver Super 55 Diesel that I am going through, replaced clutches, bearing, seals, brakes, shafts, etc. The engine runs good but shot rings and low compression has be looking are rebuilding it. My engine has 3.5 pistons and I see sleeves and pistons come either 3-5/8 or 3-3/4. I am considering upping the bore to 3-3/4 for increased displacement and compression. I'm thinking higher compression would help low temperature starting and more power. I'm figuring you pullers could steer me right. Will higher compression increase power and better cold weather starting? Also can the American Bosch injector pump be calibrated for the increased cubic inch? Thanks in Advance, Charles
